YO3KXL: WebSDR experimental
yo3ggx
Re: YO3KXL: WebSDR experimental
Mesajde yo3ggx » Mar Noi 26, 2013 11:04 pm
Am devenit din ce in ce mai curios.
Iata ce citesc chiar pe un grup care discuta probleme SDR:
http://groups.yahoo.com/neo/groups/soft ... pics/66574
The enclosed piece of paper says "stereo microphone input". It is in fact stereo. IQ balance is good, once 1 sample delay is added to the right channel
- 96kHz sampling works well, no noticeable fall-off at the edges. Anti-aliasing filter seems to be good as well, although I can see strong stations up to about 2-3kHz outside of the window. I haven't noticed any other artifacts.
- Noise is adequate for my location and antenna, i.e. when I plug in the antenna, the noise floor rises by about 5-7dB, which is good enough.
Verdict: 96kHz of good enough spectrum for $11! Great bargain!!!
Woow.
Incerc sa gasesc si eu una prin zona asta de lume si sa fac niste teste.
Dan YO3GGX
n2yo
Mesajde n2yo » Mar Noi 26, 2013 11:13 pm
Dan,
Deci jucaria mea pe care am dat 11 dolari cu free shipping are asa:
- intrare mono 96 kHz
- iesire stereo
- iesire digitala pauza
Sa vad cum se desface cutiuta aia si o sa-i fac o poza pe dinauntru.
73s de Ciprian N2YO
yo3ggx
Mesajde yo3ggx » Mar Noi 26, 2013 11:24 pm
n2yo scrie:Dan,
Unii sustin ca ar fi stereo chiar daca scrie mono.
Cum ti-ai dat seama fara sa o desfaci? Exista interfete SPDIF care sunt montate in capatul jack-ului de 3.5mm.
Conectoarele arata ca un jack:
https://www.google.ro/search?q=mini+spdif&tbm=isch&tbo=u&source=univ&sa=X&ei=KhGVUvPUBdDLswbRw4DIBQ&ved=0CD4QsAQ&biw=1366&bih=653
Ar fi grozav. Mor de curiozitate.
Am comandat deja una, dar slabe sperante sa o primesc pana la sarbatori.
INteresante si comentariile din josul paginii de aici:
http://www.amazon.com/gp/product/B006SF68P2
73 Dan YO3GGX
n2yo
Mesajde n2yo » Mar Noi 26, 2013 11:36 pm
Eu am crezut ca pentru iesire digitala trebuie conector separat. Deci poate are, dar nu-mi trebuie. Pentru intrarea "mono" m-am bazat pe specificatii, dar avand nevoie de un singur canal, celalalt daca exista este neutilizat. Apropo de alte placi audio, am facut upgrade recent la placa de baza si am luat una ieftina, dar chipsetul audio are intrare 192 kHz, cel putin asa scrie in cartea tehnica. Mai am un E-MU 204 pentru Pan Adapter la transceiver, dar pe 192 kHz e de neutilizat, doar la 96 kHz functioneaza acceptabil.
73s de Ciprian N2YO
Mesajde yo3fhm » Mie Noi 27, 2013 9:59 am
n2yo scrie:Eu am crezut ca pentru iesire digitala trebuie conector separat.
Salut Ciprian,
La XONAR D1 chiar asa este, prima mufa este sharuita pentru Line In/Mic In si S/PDIF output, folosind un adaptor de 3.5mm. Iata aici un extras din manualul placii :
Si de asemenea, iata un extras dintr-un review al placii de la Overclockers Club:
" Also pictured here is the optical audio adapter. It has the 3.5mm end covered with a protective rubber tip to keep it clean and free from scratches. Taking this tip off lets you insert the adapter into the card, and end up with a TOSLink socket for using a standard optical digital audio interconnect cable."
Uite si adaptorul aici, pe care si eu l-am gasit in cutia placii:
73s de Cezar
Mesajde yo3fhm » Mie Noi 27, 2013 10:03 am
n2yo scrie:De asemenea sistemul de operare imi da voie sa selectez la intrare rata de esantionare 96 KHz.
Ciprian,
Eu as porni un Visual Analyzer sau un soft SDR (HDSDR, PowerSDR, etc.) si apoi as trazni-o cu semnal din generator. Daca poate 96KHz, poti sa-i dai in nas pana la jumatate, si vezi cu ocazia asta ce ii poate pielea referitor la caracteristica. Sunt sigur ca ai un generator pe-acolo, hi !
Daca o faci, te rog sa ne tii si pe noi la curent!
Regards,
FHM
Mesajde yo3fhm » Mie Noi 27, 2013 10:07 am
yo3ggx scrie:Alsamixer nu poate fi folosit cu placile Xonar D1 pentru reglarea niveului pe intrari. Nu stiu ce controleaza, dar in nici un caz placa. [...] Eu folosesc xfce4-mixer in CentOS 6.2, care are control stereo pentru intrari. Cum nu am X pe server, folosesc Xming pe PC-ul de pe care ma conectez.[...]Incearca un tool X de mixer din Ubuntu daca nu ai xfce-mixer. Cu Alsamixer poti doar selecta intrarea.
Neatza' Dan,
Multumesc frumos pentru scurtarea travaliului, macar nu mai pierd timpul scormonind pe Web. Hi. Afurisita chestie. Nici eu n-am X pe server, asadar trebuie sa vad cum voi descurca itele. Asta a fost si ideea, fara X ...
Regards,
C.
n2yo
Mesajde n2yo » Mie Noi 27, 2013 10:30 am
Cezar,
Eu nu am niciun dubiu despre SD-AUD20101, l-am folosit cu programe SDR cateva saptamani, am facut si demonstratii cu receptii VLF la un star party http://www.radio-astronomy.org/node/157
Doar Dan YO3GGX era neincrezator, dar considerand ultimele sale postari, cred ca s-a edificat.
73s de Ciprian N2YO
n2yo
Mesajde n2yo » Joi Noi 28, 2013 3:22 am
SD-AUD20101A
SD-AUD20101A
Dan,
Iata si pozele promise - fata/verso de la SD-AUD20101. Daca nu se vede clar vreun detaliu, sa-mi spui.
73s de Ciprian N2YO
SD-AUD20101B
yo3ggx
Mesajde yo3ggx » Joi Noi 28, 2013 9:56 am
Buna Ciprian,
Multumesc pentru imagini. Acum sunt edificat. Ce ai tu este o interfata adevarata, spre deosebire de cele de pe ebay care sunt niste pocnitori desavarsite, cu toate ca la exterior arata identic.
Chiar exista iesirea digitala iar chip-ul este marcat corect si in capsula lui.
Foarte interesant. Abia astept sa o primesc si eu pentru a o pune la ceva teste
Imi recunosc ignoranta, dar este prima interfata USB "no name" (in acel form factor) adevarata, care sincer nu credeam ca exista decat teoretic.
Toate cele bune,
Dan YO3GGX
