Buna dimineata
Totul este OK
Balonul a ajuns in Kazakhstan (Florentin a avut dreptate---dupa ce a evitat sa visiteze Minsk si (putin) Moscova a plecat spre Karaganda...hi.
A fost receptionat in dimineata asta si in YO.
Timestamp Call MHz SNR Drift Grid Pwr Reporter RGrid km az
2019-06-19 04:26 YO3ICT 14.097086 -19 0 LN49 0.01 EU2AAH KO33 1580 295
2019-06-19 04:26 YO3ICT 14.097121 -21 0 LN49 0.01 YO8TNB KN37ew 1660 273
2019-06-19 04:26 YO3ICT 14.097080 -19 0 LN49 0.01 OZ7IT JO65df 2539 299
2019-06-19 04:26 YO3ICT 14.097079 -8 0 LN49 0.01 RZ3DVP KO85nt 1062 316
2019-06-19 04:26 YO3ICT 14.097092 -12 -1 LN49 0.01 YO8SEP KN36rt 1617 268
2019-06-19 04:26 YO3ICT 14.097078 -25 0 LN49 0.01 G4ZFQ IO90ir 3517 292
2019-06-19 04:16 YO3ICT 14.097079 -20 0 LN49 0.01 SA6BSS/RX JO68sc 2480 306
2019-06-19 04:16 YO3ICT 14.097079 -12 0 LN49 0.01 RZ3DVP KO85nt 1062 316
2019-06-19 04:16 YO3ICT 14.097092 -17 0 LN49 0.01 YO8SEP KN36rt 1617 268
2019-06-19 04:04 YO3ICT 14.097071 -20 0 LN49 0.01 EI7HZB IO65fb 3786 301
2019-06-19 04:04 YO3ICT 14.097084 -18 0 LN49 0.01 PD0OHW JO33lc 2905 294
2019-06-19 03:56 YO3ICT 14.097072 -20 0 LO40 0.01 EI7HZB IO65fb 3729 300
2019-06-19 03:46 YO3ICT 14.097087 -24 0 LO40 0.01 2E0PYB JO01is 3308 292
2019-06-19 03:34 YO3ICT 14.097087 -24 -2 LO40 0.01 2E0PYB JO01is 3308 292
Eduard am sa urmaresc si astazi cat pot. Te rog sa spui unde vrei sa-ti trimit logurile.
Balonul romanesc ICT1 a fost lansat
Re: Balonul romanesc ICT1 a fost lansat
La mine pe JT9 semnalul e prea slab pt. a fi decodat.
Mircea, nu este nevoie sa imi trimiti mie personal. Doar asigura-te ca in modul WSPR optiunea Upload spots este bifata.
Astfel, logurile ajung pe wsprnet.org de unde le iau eu automat cu un script si actualizez harta.
Multumesc!
Multumesc!
OK Eduard
Pai daca nu ar fi fost bifata nu ajungeau raportarile mele la http://wsprnet.org/drupal/wsprnet/spots
Pentru cei care nu au avut bifa pus nu e nici o problema, logul exista si poate fi vizualizat.
Pentru asta intrati in File/Open log directory si deschideti fisierul ALL WSPR.
Aveti aici toata activitate WSPR receptionata pe care o puteti trimite in baza de date a http://wsprnet.org/
Eu am inteles ca esti interesat mai mult de raportarile in JT9 decat de cele in WSPR.
O sa incerc atunci sa le redirijez spre pskreporter dar acolo le poti gasi doar pentru maxim 24h.
Incerc si capturi de ecran pentru JT9.
O zi buna, 73 Mircea YO8RAA
ps- Vad ca folosesti inca wsjt-x versiunea 1.8.0. Incearca sa incarci versiunea WSJT-x 2.0. S-au facut ceva imbunatatiri atat pentru wspr cat si pentru JT9.
YO8RAA scrie:OK Eduard
In JT9 este ok daca poti posta aici de cateva ori pe zi.
Legat de versiune, poza pusa de mine mai sus este luata de pe web. Sunt de mult la 2.0.
Sa vedem ce face azi balonul... sunt sanse 50% - 50% sa intre in jet-stream sau din Alma-Ata sa o ia spre N spre Siberia.
Oricum ar fi, sper sa faca ocolul complet.
Luati-va dupa gradientul jet-stream-ului acum arata asa la 12000m:
Probabil, Taskent - Almatai si apoi spre N-E....Pariez pentru ceva Siberia, dar e un vortex acolo , vedem.
Se pare ca propagarea nu ne ajuta astazi.
Din pacate cu toate ca am zis ca stau astazi mai mult pe la statie ...s-au ivit alte probleme.
Din constarile facute vad ca in ultimele 12h doar 3 statii din YO au avut contact cu balonul dar ce este mai dezarmant e faptul ca de pe la ora 08:30 utc singurile statii cu care a mai fost in contact sunt RZ3DVP si YO8SEP (felicitari Petronel).
Sper ca maine sa avem parte de propagare mai buna sau sa apara raportari din zona asiatica.
Atasez o captura de ieri pentru JT9.
Propagarea este cel putin dubioasa, dar mai curios este faptul ca sunt raportate cu preponderenta mesajele WSPR standard si mai putin mesajele de telemetrie, asa ca nu pot actualiza harta.
Acestea incep cu Q iar al 3lea caracter este 5.
Ca si exemplu : QA5ABC KP11 60.
Mai amintesc inca o data programul transmisiilor:
Minutul 2 - 20m JT9 - Indicativ + locator 6 caractere
Minutul 3 - 20m JT9 - Caracterele 7+8 ale locatorului extins + Altitudine + Viteza de deplasare in plan orizontal (km/h)
Minutul 4 - 20m WSPR - Mesaj WSPR standard
Minutul 6 - 20m WSPR - Telemetrie speciala WSPR
Minutul 12 - 20m WSPR - Mesaj WSPR standard
Minutul 14 - 20m WSPR - Telemetrie speciala WSPR
Minutul 16 - 20m WSPR - Mesaj WSPR standard
Minutul 22 - 20m WSPR - Mesaj WSPR standard
Minutul 24 - 20m WSPR - Telemetrie speciala WSPR
Minutul 26 - 20m WSPR - Mesaj WSPR standard
Minutul 32 - 20m JT9 - Indicativ + locator 6 caractere
Minutul 33 - 20m JT9 - Caracterele 7+8 ale locatorului extins + Altitudine + Viteza de deplasare in plan orizontal (km/h)
Minutul 34 - 20m WSPR - Mesaj WSPR standard
Minutul 36 - 20m WSPR - Telemetrie speciala WSPR
Minutul 42 - 20m WSPR - Mesaj WSPR standard
Minutul 44 - 20m WSPR - Telemetrie speciala WSPR
Minutul 46 - 20m WSPR - Mesaj WSPR standard
Minutul 52 - 20m WSPR - Mesaj WSPR standard
Minutul 54 - 20m WSPR - Telemetrie speciala WSPR
Minutul 56 - 20m WSPR - Mesaj WSPR standard
Il urmaresc de cateva ore dar nimic in JT9 deocamdata, numai WSPR, dar modest, prima aparitie in LN87
si putin mai tarziu tot in WSPR in LN97
