FOURTH BALKAN HF CONTEST 2017
Rules
1. Organizer: BFRA (Bulgarian Federation of Radio Amateurs) for 2017 edition, after that consequently other Balkan societies.
2. Participants: Only radio amateurs from Balkan countries, i.e. with callsigns, starting with (in alphabetical order): 4O, 5B, 9A, C4, E7, ER, H2, J4, LZ, P3, S5, SV, SW, SX, SY, SZ, TA, TB, TC, YM, YO, YP, YQ, YR, YT, YU, Z3, Z6, ZA, ZC4.
3. Objective: To contact as many as possible radio amateurs from Balkan countries (including own country) with as many as possible prefixes (see bellow).
4. Date and Time: From 12:00 UTC to 18:00 UTC on 12 February 2017, Sunday.
5. Bands: 3.5 MHz and 7 MHz. Change of the band requires at least 10 minutes activity on the new band.
6. Modes: CW, SSB, Mixed.
7. Categories: Category A – Power permitted to the amateur according his/her license, but not exceeding 1000 W INPUT and Category B – Power not exceeding 10 W INPUT (QRP). The participants in this category transmit /QRP after their callsign (e.g. LZ1US/QRP).
8. Exchange: CW – RST report plus the consequent number of the QSO (e.g. 589023), SSB – RS report plus the consequent number of the QSO (e.g. 57006). In case of changing the mode or band the sequence of numbers continues.
9. Multipliers: Separately for each band – the number of Balkan prefixes contacted on the relevant band. For the purposes of this contest a different prefix is each callsign that differs in its first three marks. Therefore LZ6, LZ7, SV3, SV4, Z31, Z32, TA1, TA2 etc. are different multipliers, but LZ07KM counts as LZ0, YO2014A counts as YO2, ER650MD counts as ER6, etc. Participation from area with prefix different from original counts as that prefix (e.g. SV0XCA/5 counts as SV5).
10. Allowed contacts: Only one contact with any station is valid on each band, independently on the mode (e.g. if LZ6Y makes a contact with ZA1RE on 7 MHz / CW, another contact between them on the same band, regardless on CW, or on SSB, shall not be valid; one contact between them on 3.5 MHz shall be valid).
11. QSO Points: Each contact with category A station is worth one (1) point while each contact with category B station is worth two (2) points. Repeated contacts with the same correspondent on the same band are worth zero (0) points for both (initial and repeated) contacts. Contacts logged with more than 5 minutes difference from the real time are also worth zero (0) points.
12. Final score: The final score for both categories is the sum of QSO points on 3.5 MHz band, multiplied by the multiplier on this band, plus QSO points on 7 MHz band, multiplied by the multiplier on this band (e.g. if Z32TY has contacted 20 stations on 3.5 MHz, 3 of them QRP, number of contacted prefixes 15 as well as 25 stations on 7 MHz, 5 of them QRP, number of contacted prefixes 18, his final score shall be (17+6)x15 + (20+10)x18 = 345+540 = 885 points).
13. Classification: Separately for Category A and Category B. No difference between CW only, SSB only or mixed.
14. Logs: All times must be in UTC (GMT). Logs must be checked for duplicate contacts, correct QSO points, and multipliers. Electronic logs in Cabrillo format sent by e-mail are compulsory. Write down Balkan Contest and your callsign in Subject line. Submit your logs by mail to panayotdanev@yahoo.com with a copy to bfra_hq@hotmail.com
15. Deadline: All logs must be sent by e-mail not later than 19 February, Sunday.
16. Disqualification: Violations of amateur radio regulations, the rules of the contest, unsportsmanlike conduct, use of any non-amateur means of contacts (such as telephone, Internet etc.) will be deemed sufficient cause for disqualification.
17. Awards: Plaques (or trophies with certificates) are awarded for top performance to first six (6) amateurs in category A and first three (3) in category B, as well as best participants from each country, if not in those above.
Sa fie cu propagare si participare!
Pit YO3JW
Campionatul Balcanic 2017 editia a IV-a
Re: Campionatul Balcanic 2017 editia a IV-a
Salut Pit..
Ce soft recomanzi pentru acest concurs?
Am incercat N1MM, merge, dar accepta si prefixele care nu sunt din zona balkani.
73 de yo6cfb, Lacy
73 de yo6cfb, Lacy
Laci,
Anul trecut am lucrat cu N1MM si am ales RUSSIANDX. A mers brici. 73 si succes!
Da Alex...
Si eu tot cu N1MM+am lucrat, acum stie si Balkan contest la UDC, dar spuneam ca te lasa sa faci legaturi si cu alte prefixe, nu numai cu cele Balkanice, si culmea ca le si puncteaza si baga si la multiplicator. Intreadevar, cand scrii indicativul apare cu culoarea gri, aceasta insemnand ca nu este indicativ pentru concurs, dar totus salveaza legatura si puncteaza, cea ce nu este corect.
Poate ca eu inca nu am gasit de unde se poate configura lista cu prefixele valide. Daca stie cineva acest lucru, va rog sa ne puneti si la dispozitia noastra.
73 de yo6cfb, Lacy
73 de yo6cfb, Lacy
Cred ca anul acesta participarea nu va fi grozava.
Pe saitul SK3BG, apare regulamentul de anul trecut
cu adresa pentru loguri la FRR...
Pe saitul UA9QCQ nici nu este pomenit
Acestea doua sunt cel mai folosite de contestmani.
Doar WA7BNM spune ceva despre concurs
Buna!
A mai ramas o zi pana la Campionatul Balcanic 2017
Regulamentul este la prima postare.
Referitor la ce program se poate folosi: este de preferat unul dedicat, dar se poate folosii orice program care permite lucrul in cw si ssb, da numar serial crescator si exporta in Cabrillo.
E bine sa fiti familiarizati cu programul inca dinainte de a incepe concursul!
Avand in vedere ca verificarea logurilor se face cu ajutorul unui soft care face si punctarea legaturilor, punctajul nu este relevant.
Cunoscand prefixele valabile pentru Campionat, sper ca nu este greu a elimina chemarile sau raspunsurile la statii din afara zonei balcanice.
Principalul este sa se trimita logurile pentru a asigura acuratetea rezultatului final.
Nu-mi ramane decat sa va doresc propagare in Balcani
PS Anul trecut unul din participanti s-a plans ca nu a facut rating din cauza ca avea antena pentru DX!
