Conform regulamentului/recomandarii IARU, operatorul are voie.
Competitors are obliged to follow the common definition for a valid QSO (described in the
PART 1 section 4.1). The contest exchange (call, report, QSO number and locator) shall be
sent and confirmed on the band where the contact started and only during the QSO. No
attempt should be made during the QSO to obtain any part of the required exchange
information via other communication methods such as the Internet chat channel, DX Cluster,
talk-back on another amateur band, telephone etc.. Such a secondary method invalidates the
contest QSO. Self-spotting (advertising its own frequency) on any other communication
means, like DX Cluster, chat rooms, etc. shall not be used during the contest. (Varna 2014)
Acceptable examples when using a secondary method:
"Shall we make a sked on 144.388?"
"I have QRM, let's move to 144.218 kHz and start again"
"Nothing received, please try again" and the QSO starts again
"Thank you for a nice QSO" - Note: Only after the QSO has completed on the radio!
Unacceptable examples when using a secondary method:
"I need your serial number"
"Please repeat all information"
“Please confirm <report>, <serial number>, <locator> etc.”
Stiu, ca si Claudiu este activ pe chatul ON4KST de obicei.
Din cate stiu nu a avut voie sa modifice regulamentul pe anul asta, dar sa speram ca cel de anul viitor va fi adus la punct cu recomandarile IARU.
La fel, ceea ce nu este clar este categoria SOMB/MOMB. Poate un operator sa participe si la SOSB si la SOMB? Daca da, cum trebuie trimis logul? Dintr-un post anterior, am inteles ca trebuie loguri separate pentru fiecare banda.
