Pentru cei care se gandesc la achizitionarea unui nou transceiver de scurte (si nu doar acestora), le propun sa studieze si acest model revolutionar:
http://www.codanradio.com/product/envoy/
Caracteristici:
Channels Up to 1000 simplex or semi-duplex
Scanning Up to 20 scan groups
Simultaneous scanning for Selcall (ALE / CCIR) and voice
Dwell time 125 ms to 9.9 s, adjustable
Contacts List Up to 500 entries
SDR processing architecture DSP, 456 MHz, 32-bit
FPGA, 500,000 gate
MCU, ARM9, 300 MHz 32-bit
Interfaces USB (via Handset or Console)
Serial RS232 (supports NMEA-0183 GPS)
Ethernet (TCP / IP, supports remote control)
Auxiliary GPIO (audio in / out, PTT, RS232) on Envoy™ X2 model
Audio response Less than 3 dB variation from 300 Hz to 3 kHz (with optional 2.7 kHz fi lter)
Compliance CE, NTIA, FCC, AS/NZS 4770:2000, AS/NZS 4582:1999 (pending)
Temperature range –30 to +60°C
Humidity 95% RH maximum, non-condensing
RF
Frequency range Transmit: 1.6 to 30 MHz
Receive: 250 kHz to 30 MHz
Frequency Stability: ±0.5 ppm from –30°C to +60°C
Modes Single sideband (J3E), USB, LSB, AM (H3E), CW (J2A), AFSK (J2B), F1B (FSK) (software
controlled fi lter bandwidth)
Output power 125 W PEP ±1 dB (two-tone or voice), user-programmable (low / medium / high)
Duty cycle 100% Voice / Data with optional Fan
RF output impedance 50 Ω
Filter bandwidths 2.4 kHz standard (500 Hz, 2.7 kHz optional)
Wideband software programmable fi lters available on Envoy™ X2 model
Transmitter specifications Spurious and harmonic emissions: Better than <64 dB below PEP
Intermodulation products: 33 dB below PEP
Carrier suppression: Better than 60 dB below PEP
Sideband suppression: 70 dB below PEP
Receiver specifications Sensitivity: 0.12 µV, –125 dBm for 10 dB SINAD
Selectivity: >70 dB at –1 kHz and +4 kHz ref SCF USB
Blocking: >95 dB at ±50 kHz
Image rejection: >70 dB
Spurious response: >70 dB
Intermodulation: Unwanted signal >92 dB below desired signal
Switching speed <25 ms (Tx:Rx or Rx:Tx)
ELECTRICAL
Operating range 10.8 to 13.8 V DC (12 V Nominal)
Supply current Receive: 500 mA (backlight min, audio muted)
Transmit: Two-tone 12.5 A typical, average speech 8 A
Protection Over-voltage / under-voltage / over-temperature / reverse polarity
Daca nu e destul, sa stiti ca mai are module pentru CIVS voice encryption, data modem, IP remote control, GPS...
73 !
Transceiver HF SDR 1.6-30MHz ENVOY
Re: Transceiver HF SDR 1.6-30MHz ENVOY
Tehnologia e interesanta, insa e un transciever complet inutil pentru radioamatori din moment ce nu are un mod VFO.
Interesant, dar dupa cum scrie si producatorul, aparatul este gandit pentru:
- scop umanitar
- comercial
- siguranta publica
- securitate
- uz militar
Eu personal as prefera un KX3...
Toate cele bune,
Dan YO3GGX
- scop umanitar
- comercial
- siguranta publica
- securitate
- uz militar
Toate cele bune,
Dan YO3GGX
