Buna seara,
imi cer scuze daca sunt inoportun, am observat urmatoarea postare pe Facebook si pe site-ul http://www.hamradioweb.org:
"New K4, fake or not? Updated, is real !" https://elecraft.com/products/k4-transceiver
"Actualizat, este adevarat... aici este pagina web de pe site-ul Elecraft, nu este inca indexata, nu este in meniul de navigare, nu exista informatii, dar exista imaginea si este suficient."
Cu respect, Calin YO2LOG
Noul Elecraft K4
Re: Noul Elecraft K4
Sunt si ceva informatii despre K4:
• DIRECT SAMPLING + OPTIONAL SUPERHET (HDR) MODULE
Direct sampling allows for advanced filtering, NR, NB, noise nulling, etc.;
Optional HDR module provides the ultimate in dynamic range
• 160-6 M, ALL MODES, 100 W / 10 W; WIDEBAND DUAL RECEIVE
Main/sub receivers can be on same or different bands; single or dual panadapters
• MODULAR ARCHITECTURE
Add HDR module, future 15 watt VHF/UHF module, etc., as needed
• OPTIMIZED USER INTERFACE
Encoders for VFO A, VFO B, RIT/XIT offset; many user-programmable controls
• HIGH-PERFORMANCE TUNING AID
High resolution mini-pan, per-receiver, for accurate tuning & search
• NO-COMPROMISES CW
Silent PIN-diode T/R; fast QSK; many features for CW ops
• EXTENDED I/O
HDMI, Ethernet, analog/digital audio; ATU with 3 ant. jacks; up to 5 RX ant. sources
• VERSATILE SOFTWARE ENGINE
Powerful, fast-booting CPU accommodates future in-box software applications
• PORTABILITY
Light weight, low current drain – compatible with field operation
SPECS
STANDARD FEATURES Size: 4.5”H x 13.5”W, 10” D Weight: Approx. 10 lbs Supply Voltage: 12-15 VDC Current: ~2 A RX, ~18-23 A TX Frequency Range: 100 kHz - 54 MHz (VHF/UHF range to be determined*) Stablility: +/- 0.25 ppm (TCXO) Modes: CW, SSB, AM, FM, Data LCD: 7” color; touch & mouse control Text modes: CW, PSK31/63, RTTY KAT4 ATU: 10:1+ range; 3 ant. jacks RX antenna sources: Up to 5 A-to-D Converter(s): 16 bits
I/O: USB-A x3, USB-B (two virtual com ports + audio), RS232 (DE9), Ethernet, HDMI. front/rear mic, front/rear phones, LINE in/out, speakers, PTT in, KEY out, paddle, key, ACC,12 V out. CW QSK: Silent, PIN-diode switched Other: RX/TX EQ, real-time clock,100% remote control including panadapter data, remote antenna switch control*, custom in-box software apps*
"Se pare ca este răspunsul lui Elecraft la 7610 și 101DX", scrie IW5EIJ, ca un comentariu la postarea initiala, cu un titlu prudent "K4 Elecraft or not ??"
• NO-COMPROMISES CW
• EXTENDED I/O
• PORTABILITY
SPECS
Acum cateva minute a dat stirea si QRZ Now: Elecraft K4 – High Performance Direct Sampling SDR
https://qrznow.com/elecraft-k4-high-per ... Utl0w16r50
Daca Elecraft pana acum a pastrat un design specific, de aceasta data parca a fuzionat cu FT - Yaesu etc. "Stralucirea si decadere a curtezanilor" (H.Balzac...
Fiti fara grija, Elecraft va pastra plasticul ordinar pentru butoane si in general aspectul de chinezarie ieftina... sa stii pe ce dai banii!
P.S. "...curtezanElor"
Am stat un pic de vorba la Hamvention cu Eric Swartz WA6HHQ, co-proprietar al firmei Elecraft despre noul transceiver K4. Mai multe detalii in curand.
73 de Ciprian N2YO
73 de Ciprian N2YO
@N2YO: astept cu interes si nerabdare sa citesc interviul cu Eric dar si restul materialelor de la Dayton/Xenia.
73 de Morel 4X1AD ex.YO4BE
Deci pana la urma apare in doua variante,
Nu se spune nimic prin ce se deosebesc.
Nici nu sunt scumpe la 4000$ daca vrei sa lucrezi Bouvet ...
Dar cu 4000$ poti face parte din echipa de operatori ..hi
Dati clik pe imagini pentru marire.
73 Mircea YO8RAA
https://swling.com/blog/2019/05/first-look-elecraft-k4-photos-and-preliminary-information/
73 Mircea YO8RAA
@YO8RAA : daca te duci pe site-ul Elecraft ai sa gasesti suficiente informatii preliminare despre noua familie K4. Pe scurt, vor fi 3 configuratii: K4, K4D si K4HD. Configuratia de baza K4 va fi comercializata si sub forma de no-solder kit. In timp ce primele doua configuratii sunt in tehnologia SDR Direct Sampling, versiunea cea mai complexa K4HD va avea si un modul care va adauga in fata receptoarelor SDR un etaj in tehnologie clasica de superheterodina pentru o imbunatatire simtitoare a performantei dinamice. Familia va fi modulara astfel ca un K4 de baza va putea fi upgradat in timp la configuratii mai complexe.
Vezi: https://elecraft.com/pages/k4-pre-order la capitolele "Introduction", "Overview" si "Models"
yo4hgx scrie:Fiti fara grija, Elecraft va pastra plasticul ordinar pentru butoane si in general aspectul de chinezarie ieftina... sa stii pe ce dai banii!![]()
au ce au cu aspectul de "casa pionierilor". la banii astia puteau sa mai umble la materialele de finisaj si design.
